But you have to use the word "are" not "is".I thought Watts = V x A x PF = W, and V x A = VA
Roger
Roger
No. Even zero is something.I have one question, does zero equate to nothing?
Roger
Not quite, the area under the v*i curve represents energy. You must divide by time to obtain average, real power.
What you call mnemonics I was reading as a typo or the use of the label. The label W would use "carries" while the rate it stands for (watts) would not. "The numerator carries...", "The denominator or product carries", etc.Mivey, it irritates my tender psyche to hear expressions such as,
"The watts is equal to the volts times the amperes."
That's the obvious answer, and why it is or isn't correct is the whole point of this thread.This is basic Ohm's law. E(I)=P
200 (5)=1KW
It did not occur to me that anyone reading this phrase "...W/VA which is power factor" would say "W" stood for work. Why would you be mixing units with abbreviations?
My point was though that the average of the vi product in this case is real power into the device, not apparent power. Divide that by real power our to obtain efficiency.
watt (real power)
volt-ampere (apparent power)
is POWER FACTOR
No argument there, but how do you calculate apparent power?
Apparent power is Vrms * Irms
Instead of multiplying them simultaneously and integrating the product, the RMS values are calculated separately, then multiplied together.
It's literally Vrms * Irms
That's the only way you can get away with calculating the power from only one measurement. If you can't assume a perfectly linear load with no phase shift(an ideal resistor with no reactance or capacitance) , you can't get away from having to simultaneously collect V*I and integrate the product.
You're right. Fine, the area under the curve of |V|*|I| divided by whatever the integration period is in seconds gives Pavg in watts for whatever the duration of integration period used.
