Use duct tape for warts.
Is it the FABRIC, or the ADHESIVE that effects the wartage?
db
lack of air. This is from a doctor.
And when the current increased enough, the manner of death changed. Above 50mA it only takes a fraction of a second to put you into fibrillation reqardless of the any further increase in current. Above 200mA death from burns follows the current/time curve. Oh, but what was that? Time? That would mean POWER not CURRENT.
Actually the defibrillation machines used clamped sinusoidal waves and have progressed to fancier wave forms since then. The use of different wave forms dramatically changes the success rate of restarting the heart. DC has a tiny chance to help not because it creates fibrillation but because it completely stops the heart. Then you hope the heart has enough health left to start itself correctly. Hmm, this would mean FREQUENCY has a substantial impact on heart rhythm. No no, we should have just cranked the DC current higher.
My wife had a similar opinion but I didn't think it was stupid at all.
I used it to burn off a wart. It was effective, saved me the cost of an office visit plus treatment at the doctor, the hassle and time lost going there, and it didn't hurt that bad.
I won't argue, but hot metal does it quicker.
And while it is a quite silly example the truth remains that there was a lot of current present during my home medical procedure and I was never in fear for my life.
Not having a PHD nor even know how to sling the BS but one thing I do know is that there can be no electrical power without the flow of CURRENT.
I also know that the FREQUENCY is the rate of change of the CURRENT.
Ions both have a positive or negative charge and will aid the flow of CURRENT
An arc flash has heat and you made the statement that current is heat therefor the flash has CURRENT.
Maybe you should rewrite all the safety manuals and charts that have been around for years that clearly state that it is the current that does damage.
I will continue to use that which is printed by my government (OSHA) which states that it is current that does damage. Me and my dumbed down government stand pat; it is the current that does the damage.
pray tell us what is
So I will stick with it is electricity that kills, not exclusively the voltage or exclusively the current.
It is not an untrue statement but it is hardly a complete statement.
It is voltage, it is current, it is time as Brian pointed out and I bet other factors as well.
Again it is not an either / or type question.
Mike, it is many things, it is not one thing.
Actually, most of those charts presume that voltage is a constant and that current is being controlled. But feel free to check your charts again such as SCCR ratings. You'll see that they take voltage seriously, because in the end it's the amount of power delivered. And for a given amount of power, voltage and current are inversely proportional.
You are trying your best to bring physics into a simple problem.
We both know that power can’t exist unless there is current. We both know that voltages or dielectric breakdown if you wish is nothing more than the amount of pressure it takes to push the current through the resistance.
We both know that current is what moves and delivers the power or energy to the load but we both know that energy does not necessarily mean that voltage or current is present. A blown out tire releases energy without voltage or current.
Voltage does not move, power is the result of voltage and current. Electrons move and the movement of the electrons is measured in amperage or current.
Call it dumbing it down or whatever you want to call it but the basic answer to the original of which kills voltage or current the answer is current.
I shall not waste any more energy (no voltage or current in use in this energy) responding any future.
That is an opinion, it carries as much or as little weight as my opinion or anyone's and IMO you are mistaken.
You are trying to use the physics of current flow to prove something that most can?t understand.Ah, now I see the error of my ways. The physics is contradicting the simple solution.
You say that it is energy that causes the ill effects of current flow. Energy is how much power that is being consumed over a certain amount of time. Energy in most cases is measured in joules. One joule is the amount of energy that is needed to move one pound nine inches in one second. One joule per second equals one watt of power.
When I get on my treadmill for one hour I will expend about 1000 joules of energy and it does not constitute death so to say that energy causes death is false.
Ohm?s Law has four components, Power or watts, voltage, current or amps, and resistance.
Current is the movement of electrons. Current is what that moves through the circuit.
Current or the movement of electrons through muscle tissue of the human body causes the muscle to contract. When current moves across the heart muscle it causes the muscle to contract into a tight ball and when released can cause fibrillation and death. It is current that causes injury or death. It is the flow of electrons through the human body that causes the ill effects plain and simple.
It doesn?t matter if you believe it or not it does not change the laws of physics that you are trying to use to prove your point.
Printed by Cutnell, John D., Johnson, Kenneth W. Physics. 4th ed. New York, NY: Wiley, 1998.
?Currents of approximately 0.2 A are potentially fatal, because they can make the heart fibrillate, or beat in an uncontrolled manner."
Notice there is no mention of voltage or frequency.
Printed by Watson, George University of Delaware. March 8, 1999.
"0.10 amps death due to fibrillation 0.20 amps no fibrillation, but severe burning, no breathing"
Again no mention of voltage or amount of energy
Printed by Zitzewitz, Paul W., Neff, Robert F. Merrill Physics, Principles and Problems. New York: Glencoe McGraw-Hill, 1995 (McGraw-Hill is one of the text books I use)
"The damage caused by electric shock depends on the current flowing through the body -- 1 mA can be felt; 5 mA is painful. Above 15 mA, a person loses muscle control, and 70 mA can be fatal."
What about the voltage and frequency or the amount of energy? Did you forget about all these things?
I can?t help but wonder why all these experts disagree with the notion that voltage or energy does the harm but all agree that the amount of current causes the ill effects. Maybe it is because they just don?t understand physics or have the wrong opinion. At any rate I think I will stay with their opinions as they seem to be a lot smarter than I am.
I don't have those books to pull out. I've read plenty though. They typically select 120VAC @ 60hz to test against here in the US. In the experiment set up they state explicitly that they use that setup because it's the most likely for the typical person to be exposed to. Most often they then state that at different voltages and frequencies that the current values will change.
The voltage can be 25 to 25,000 AC or DC, line voltage or communication line. One can be in contact with the circuit from one nanosecond to all day. But the one thing that remains constant is the amperage. AT 100 milliamps death can occur at any voltage or frequency.
A single pole 120 volt GFCI breaker opens at 4 to 6 milliamps
A Double pole 240 amp GFCI breaker opens at 4 to 6 milliamps
What changed? Was it the frequency? Was it the voltage? Was it the amperage? Why?
I suppose that UL hasn?t yet learned that the GFCI device should open at different amperages when the voltage or frequency changes, oh well??????????
