Roughed in a house awhile back, passed inspect everything good. Well got a call the plumbing failed inspect an that they were going to have to replace some floor joists that the plumber drilled to close to edge for the drain. So I had to go back an remove some wiring that went thru the same joists. Ok did it then came back a week later an reinstalled my wiring. Then yesterday he called and said that he decided to redo the laundry room walls and that I needed to come an put my wires ( dryer and washing mach.) back in the new walls. I show up and the carpenters had pinched my wires between 2 studs. Called owner and told him that it would have to be repulled and that it would cost x amount plus the amount for moving wiring for plumbers to fix there work nad he hit the roof. Said I was the highest paid contractor there and that I had blew his budget for the job an he didnt have any money left. He was refering to the change orders for the lighting and dedicated ckts he added. The way I feel is my work passed inspect and I was done not my fault the plumber an carpenter messed my wiring up and needed to be fixed. By the way the plumbing has failed inspect 4 times so far an still hasnt passed. So he said he'll get the carpenter to fix it and I tell him that he cant its under my license and I dont want the liability. So now where at a stand off what should I do? Thanks
