What's Wrong Here ?
goldstar
New Jersey
Electrical Contractor
Someone sent me this photo so I thought I'd share it with all of you. See if you can spot the violations. At my first glance (aside from the rodent being in there)
  • The 3 pipes are of different sizes
  • Only one is unthreaded
  • One of the blades isn't locked into the jaws
:) People actually do these things !!!
  • 3 Phase Disconnect.pdf
What type of fuse rating would you get with this type of set-up. Certainly not available in a GFCI configuration I am guessing.
None of the above. Should have used black steel nipples instead of galvanized, conductivity is better, plus no worries of galvanic corrosion
No, only problem, pipes were not all same size length or diameter giving an uneven resistance across the phases, causing the load to be unevenly distributed to the motor and heating of the parts,......lol
But is the or was the conductor on load side fuse connection far left a white one? And where did the red conductor kind of laying on the bottom suppose to go? Why was green ground wires going to the neutral bus and no white neutral wires?
I wish I could answer your questions. :cool:
There is nothing wrong with that it goes along with everything else people do what they want and they don't care. And they certainly don't care about other people
