david
- Pennsylvania
So how do you, personally, keep service risers outside of the building? Do you maintain 18" of dirt all the way up to the meter socket? Do you build a concrete chase up the side of the building to the top of the mast?
it?s clear that you cannot pass unprotected under a building, or 230.6 is mute. How do you apply 230.6 and when do you determine you are passing under a building?
I read many comments here in other threads that when you brake the plain of the building footprint you must provide a service rated disconnect.
