Eddy Current
What is considered the armature in a simple one loop motor? Is it the shaft that turns the wires, the wires or the whole thing?
I would call the whole thing the armature and call the wire loop the armature or rotor winding.What is considered the armature in a simple one loop motor? Is it the shaft that turns the wires, the wires or the whole thing?
In AC machines, the armature is stationary and is called stator.
That definition is for both DC and AC rotating machines.Electrical
Armature: The power-producing component of an alternator, generator, dynamo or motor. The armature can be on either the rotor or the stator.
an armature is also the moving component of a relay.
The definition in post #4 does not exclude AC machines.That definition is for both DC and AC rotating machines.
My last post singled out AC rotating machines.
I never said so.The definition in post #4 does not exclude AC machines.
" In AC machines, the armature is stationary and is called stator. "I never said so.
Learn from me. It is there: In AC rotating machines, the armature is stationary and is called stator.I accept that, in your vast experience of rotating plant, you may have stumbled across other terminology.
In the interests of forum harmony, may I respectfully decline your very polite, kindly, well-intentioned, generous, noble, and magnanimous offer?Learn from me.
OMG!! He's using SARCASM!!!In the interests of forum harmony, may I respectfully decline your very polite, kindly, well-intentioned, generous, noble, and magnanimous offer?
And that's the great thing about the British: they have that ability to deliver a devastating verbal slam while still being unfailingly polite. (Now I must go slap myself for stereotyping).In the interests of forum harmony, may I respectfully decline your very polite, kindly, well-intentioned, generous, noble, and magnanimous offer?
Almost all AC machines have a stationary armature.
I never went to school for motors but for as long as I have known what to call what AC induction motors have a stator and a rotor. Stators stay put, rotors rotate.Learn from me. It is there: In AC rotating machines, the armature is stationary and is called stator.
We must recognize that field terminology often diverges from the fundamentals. Unless we occasionally go back and look we may adopt the field use and forget the basics.Anyway, IRL, I have never seen or heard armature used for anything other the the moving part of either a DC rotating machine or relay or contactor.
The stationary part of an AC machine is usually referred to as the stator and the moving part as the rotor.
My offer declined. What about rcwilson's offer?
Because Besoeker's definition includes both.Don't you see a conflict in that statement. How can it apply to both AC and DC yet when it is AC it is different:?:?
If Sahib meant "all" then he was wrong.Notice he used the word "almost" in there. That kind of lowers the meaning of the word "all" in this instance.
