Smash
- Philadelphia suburbs, PA USA
So we can assume you are an Electrician and all the work you do is for Free and out of the goodness of your heart right. Clearly you are expressing your opinion and again entitled as such. However, I disagree and will leave it at that. You make a lot of assumptions about the people who make efforts to make codes better and safer but do not actually back any of the information you rant about up.
I see you have an affection (maybe not) for back wiring and quick connect devices. Can you cite any issue where the fire was attributed to them directly as a result of their faulty manufacturing process or is it possible they were installed incorrectly as well and it is just easier to point fingers at the easy target. Greed you say....in a country where capitalism is king and you have the right to charge humble fees or outrageous services for needless add-ons....you thus have the right to do so and thank god you do.
Also considering the majority of inspectors make very humble wages...to think those "conscience inspectors" are reaping the rewards of your failed inspection is completely a fantasy. But hey......I am (as you) entitled to that opinion that is in disagreement with you.
Opps...Guess I did not leave it at that....My Bad!
Yes I can I've found in one case in a bedroom where a neural had come loose from a quick connect. When a maid plugged a vacuum. The motor completed the circuit never tripped the breaker and caught the back of the house on fire. House was 1.8 million dollar home less than a year old. Another house fire I was on was caused by a quick connect on a lighting circuit. The whole second floor lighting including attic and ceiling fans the hots were daisychained and burnt due to a weak quick connect. Sometimes these problems don't get found until someone pulls out the receptacle. Like a painter, or wall paper hanger who simply unscrews the outlet pulls it from the wall a little bit but that's enough in some occasions to loosen a quick connect. If no one sees this as a problem and think I just have an agenda that's sad. I've seen many fires and believe to have found repaired several loss of power problems all quick connect related that could be potential fires. I'm not in any way trying to say the whole process is wrong or corrupt and many many good safety requirements have been correctly implemented. However this really needs a second look. Your final electrical inspections won't find a loose quick connect nor should they. It's all put on the shoulders of the installer so for me to sleep at night I never use them.
Real quick I'm not looking for a argument and the inspectors I'm talking about are at the highest level where laws and arguments against laws decisions are being made. Any safety concerned electrician who gives a damn about what happens after he leaves cannot possibly feel confident with a quick connect and will never convince me myself just me otherwise.
What happens when the homeowner decides he can put that dimmer in look how easy just plug it into the back when the house burns down who's fault is it ? The homeowners ? Or the stupid fast way he could install said dimmer. That's it bottom line for me ?
