Curious as to what the inspection process is for a whole house generator install.
Is it correct to say that the unit has to be able to supply power to the entire connected load?
I realize that load shed modules can be installed to drop out high wattage loads and that in doing so you can reduce the KW rating.
What I am finding is that inspectors are not requesting any type of load data when they are inspecting these installs.
There are quite a few local contractors who are putting in under sized units, charging top dollar, and not getting called out on it.
Does anyone else notice a lack of proper enforcement when it comes to these installs.
