In your area. Ultimately, who's responsibility (legally) to make sure a permit is pulled? Residential or Commercial
This is a very good explanation but I'd like to expand on this a bit. As I understand the process (and someone please correct me if I'm wrong), if the HO pulls and pays for the permit HE is assuming the responsibility for the work. Now, if he goes ahead and hires a licensed electrician to actually do the work (and technically speaking that electrician is not supposed to do the work even if it is his neighbor), while he will probably get a better installation than if he did the work himself, he still bears the responsibility for the work.Here in MA a homeowner can pull an electrical permit and do the work himself for a single family only. (and only for his house)
If you are an electrician and doing the work yourself you must have a license to pull a permit. You need to show proof of insurance or a permit will not be issued. There is an option on the permit where the owner of the property can waive the insurance requirement.
If you are an electrical contractor you need to have a masters when you pull a permit and you must provide general liability insurance along with workers comp.
A builder cannot pull an electrical permit.
Now, let's assume something goes wrong on the job (i.e code violation, electrical fire, damage, etc.) that homeowner's only recourse would be to the electrician personally and not the electrical contractor's company. I wouldn't think that the contractor's insurance would not come into play seeing as how he did the work without a permit.
Understood. The point I was trying to make clear is that an electrical contractor has some protection through his company's liability insurance. Doing work without a permit may not afford him that same protection IMHO.
You also have to consider that not all work requires a permit - and just what work does require a permit can very a lot from one jurisdiction to another.
That totally depends on the rules of the jurisdiction, not the NEC. NEC doesn't address AHJ administrative rules in any way.if anyone is on the 2008 - 2014 nec "" any new wiring reguires a permit! Wether or not the local AHJ upholds the law is a different issues all together
