kwired
Electron manager
- NE Nebraska
- EC
In our locality we do not require a second rod. I won't talk you out of a second rod but one will pass. Our reasoning isn't due to any electrical theory but our position on what we can legally enforce. We cannot prove a single rod doesn't meet the requirement and do not expect the contractor to purchase necessary testing equipment. That being said, I'm glad the 2011 language was changed. We are currently under the 2008. May not be the most sound reasoning but the contractors like us....until the next Code change!
Like I said earlier, that is likely a big reason for the change. No inspectors had equipment to test the resistance, and had little ground to require the second rod, with the rewording it basically makes the installer prove he has low enough resistance or he drives a second rod, less to question if you don't want to prove resistance of the first rod.
