Carultch
- Massachusetts
Everytime i read the EE threads here my head hurts ,and i end up with more Q's than A's....yet i am compelled to risk a relevant (i hope) Q....
Just what is a 'sine wave'?
Way back i was told the electrons in any given atom (CU) don't necessarily 'flow' , they charge each other via some big back/forth 'bump' to any given load...
The magnitude ,or peak, was simply the flux @ certain degree of generator rotation.
Am i close....??
How the physics of VD are further altered here escapes me , but i have to start somewhere
~RJ~
Just what is a "sine wave"? Good question indeed. It isn't like it is an elementary shape that we instinctively know how to draw with a compass and a ruler.
The way that I was taught the definition of comprehensive definition of sine for all angles, was with a hypothetical roller coaster ride called the "circle of terror". It has a circular track, with a radius of 1 km. The kilometers are marked out along the arc length of the track. On the dashboard of the roller coaster, there is an altimeter and an odometer. The track is centered at sea level, so the altimeter reads zero when the coaster is half way up the track. Steve rides the roller coaster, and wonders about the relationship between the distance the cart travels, and the odometer reading. He calls this function s(x).
So sine waves are a projection of a circle's coordinate points, as you trace a given arc length or angle around the circle. Sine gives vertical, and its complimentary function cosine gives the horizontal. Mathematicians like angle units of radians, which are a radius angle. 1 radius wrapped around the circle, and the corresponding angle. It is seen as a "natural" angle unit, unlike degrees which are based on the number 360.
Sine waves are understood to be the "pure" waveform with only one frequency. The variation is as continuous as can be. Every level of rate of change for the sine wave is also a sine wave with no more than a phase shift and amplitude change. A triangle wave, square wave, sawtooth wave, or any other repeating wave shape you might imagine, is just a combination of numerous sine waves of different frequencies.
