Carultch
- Massachusetts
Can a diode be compared to a neon indicator?
It was a break down voltage (forward voltage?__:?) and has a negative run away resistance.
Similar, in that it has a bias to the direction of voltage. Although diodes usually have nothing to do with neon.
A diode in general, is a component that is built to act as an open circuit in the reverse bias direction, and as close as possible to a direct connection in the forward bias direction. When it is a perfect open circuit in reverse bias, and acts as a perfect direct connection in forward bias, that is an ideal diode. A real diode has losses in the forward bias direction that typically follow an exponential curve, and a breakdown voltage in the reverse bias direction.
