jumper
- 3 Hr 2 Min from Winged Horses
PS: Good night. The guineas have long been in bed and I should be too.
G'nite my friend.
You are missing the actual discussion, if you think this is about 1-phase versus poly-phase.Is it in fact single phase or more ...
Well, I thought that I would drop in again to see if you have this world problem has been solved solved yet. Is it in fact single phase or more and is the jury still out to lunch or more correctly stated as in deliberation.
In the meanwhile I'll contemplate if I should mount my convenience outlets with the ground up of down.
Ok, the graphic below shows what I asked you to try. You will notice that the artifact on the primary does not shift in time for the secondary waveforms. I have a different artifact for each primary winding and you can see how it shows up on the secondary. No time shift. But the red, white and blue secondary voltages have 0?, 240?, and 120? voltages. The 120? voltage is the result of phase shifting other voltages but there is no time shift in the delay or advance sense. Only if we compare the peak times of the waves do we talk about a time shift for the artifacts.
If they were phase shifts related to time shifts, the anomalies would move. But these are phase shifts related to physical shifts. These are also called phase shifts in our industry as shown by my references in #1744.At this point it is still the same inversion that is used in the single phase example, and no phase shift is required. However, you can still apply the same mathematical inversion/phase transformation that you choose to use in the single phase system and reach the same result you show below. The difference is, that by acknowledging that these are inversions and not phase shifts, it explains why the anomalies don't shift in time with the apparent shift in the waveforms.
If they were real phase shifts and not just apparent the anomalies would shift too.
Fair enough?
Looks like Rick has wimped out on me.
Won't explain how a sine function can have two phases at the same time.
Can anyone else explain it?
Every sparky knows he's working with 2 phases in a standard residential panel, and better not get them mixed up! If I have to be careful with tandem breakers, and not getting my multi-wire legs on the same phase etc., how does "single phase" apply?
Because they pull off opposite ends of the same utility transformer (ie. one winding)? Because they cancel out on the neutral with 240V? Or is it a misnomer. I've always been curious about this.
I don't understand what it is you are calling a physical shift. Nothing is physically moved, so this does not seem to be an appropriate term. I've never heard the term before, so I don't think I could agree that it is industry standard. Nevertheless, even if something has a name by common convention, it doesn't make it what the label describes. Our industry has many examples of this, and as Rattus has pointed out, phase is one of them (as opposed to "leg" or some other term).The phase shifts caused by physical shifts are not the same as phase shifts caused by time shifts. You do not have to agree with the terminology, but the physical shifts are also recognized to be phase shifts and that usage has been in place for a very, very, very long time and I doubt it is going to change now.
Yes, connecting to the winding endpoints, you have a fixed voltage source between two terminals and so, a energy potential between the terminals. You are calling each terminal a different phase and hung up on a naming convention. As you step through the winding from one end to the other, each winding is matched in phase and so, is added in series and adds voltage between the terminals.
Adding a third terminal at the midpoint of the winding and placing your measuring device common at the center, this baffles you, as your measuring protocol takes the origin reference point at the winding center instead of at the winding endpoint. Now, stepping through the winding using center as the origin, the windings appear to have reversed their winding directions on your measuing instrument, when actually the windings have not changed. What has changed is a reversal of the polarity of the instrument leads relative to the winding turn direction. You see an artifact of your measuring protocol, not an actual reversal of the winding turn direction. The windings are fixed at the factory and wound in the same direction.
This is where sin(wt -+ 180) refers to the reversal of the polarity of leads of your test eqipment on connection to the actual. The 180 deg phase displacement is a special case of reversing polarity, magnitude, or displacement along the same line. Operating or moving along the same line, this special case is where the math reduces to a one dimensional solution and there is no projection or variation in any second dimension, such as the Y axis or the rotation of a phase angle. Rotating the phase angle by any amount other than 180 deg would require a two dimensional coordinate system and a projection or variation in that second dimension, such as the rotation of a phase angle.
Your partners introduction of actual phase shifts elsewhere in the system does not help relieve you of your uncertainty about what exactly is really going on.
Bes I apologize for not responding earlier. I scrolled past this post, because I thought you were responding to someone else.It's relevance is that the same 120-0-120 (or whatever voltage) arrangement is used.
All connected like six spokes of a wheel.
Here's a piccy:
Arrangement A is the usual residential arrangement. The one you want to call single phase.
Depicted in blue.
Arrangement B shows that exactly. Plus the exactly same arrangement from the other two of the three phases.
Yet it is a hexaphase arrangement. Hex. Six.
Working backwards from that, how do you get from six to one?
Sure,we all ready did this one: when phi0 = 0...
What is the phase of said function? Is it (wt + phi0)? Can you twist the math around to make the phase equal to (wt)? If you say you can, please justify your answer.
Nope can't do that; but I can make sin (wt) = 0 = sin(wt + pi). If you would just quit trying to indiscriminately swap the applicationIndeed, the trivial case, but what if phi0 = PI?
dan, the question was about sine functions. No mention of voltages or currents or transformer windings. Let me rephrase the question:
Consider the sine function sin(wt + phi0), just a simple trig function, not necessarily representing anything.
Nope can't do that; but I can make sin (wt) = 0 = sin(wt + pi). If you would just quit trying to indiscriminately swap the application, you might actually learn something new.
