mivey
I choose to stick to the topic at hand which is the voltages and the associated phase relationships we get from transformers. I have defended my usage per the topic at hand. Your choice to talk about how the term phase is used with things other than transformers and about time shifts that are not really relevant to what I am talking about.Then why do you continually insist on using words like "real" and "physical" if you are not willing to defend them?
I simply choose not to engage in a discussion about a different topic, other than to say that the phase shifts we get from the transformers are not time shifts. But since we are not talking about those type shifts anyway, so what? Keep talking about a time shift if you want, but it is not the topic I am discussing in this thread. I feel no obligation to defend something I am not discussing nor do I feel obligated to engage in a debate over something I am not discussing.
I use those words because of what has been recognized to be a phase shift by taking voltages from different terminals and in different winding directions. That is the real shift I am discussing. It is factually incorrect to say that these physical manipulations can produce a phase shift in transformers, but then if we look at the two windings all by themselves the phase shift goes away.You chose those words for a reason and you accentuated them repeatedly for a reason.
Looking at a single-phase transformer: As part of a larger configuration, the change in winding direction produces a phase shift for the voltage from that winding and this is recognized in the numerous references I have posted. Looking at that winding as part of a larger configuration vs. looking at it by itself does not change anything because the physical action and physical reaction is exactly the same in both cases.
The facts as supported by the posted references is that taking a voltage in a different winding direction produces a phase shift for that voltage. The fact is that it can do the same whether the transformer is by itself or used as part of a larger configuration. The physical action and physical reaction is exactly the same.
