The least expensive way is to eliminate those disconnects, unless your AHJ interprets that meter post as being a structure, then 230.70 might require a main out at the meter. EDIT: Or the utility requires a main there.
The size of the wire before the meter is probably per NESC by utility and after the meter NEC, per the calculated load.
