petersonra
- Northern illinois
- Semi-retired engineer
A while ago there was some debate about the cost and long term viablity of wind power. My little brother is an economist who specializes in dealing with the electric utility industry. So I sent an email off to him and asked him what he thought. This is what he said.
wow. power that requires near 100% backup capacity, and costs 2 to 5 times what other sources cost. what a bargain.
BTW, he is a liberal democrat.
Well that's a loaded question! It depends on what you mean. I did a study for XXXXXXXXXXX in 2007 and claimed that less than 20kW is about $2400-$3000/kW, for the larger units you might get that down to between $1000/kW and $2000/kW. The variable cost are not zero, however. They can be as much as 2 cents a kWh. Also, as you know, these resources are not dispatchable by the system operator, given the intermittent nature of the resources the cost could be anywhere from 9 cents/kWh to 23 cents/kWh. Ah but there is more, the system as it is designed now is a "dumb" system. That is, there is really no way to use load as a resource (e.g., VARs) Without that ability, most system operators claim that they cannot handle more than about 15-20 percent wind on the system (without expensive upgrades to existing traditional generation or the building of new generation to back up the wind generation). In fact TX had a near collapse of the system in 2007 when the wind just stopped blowing for about an hour! Now you can see why the issue is so murky.
