peter d
- New England
Yeah, those are very practical when you have multiple conductors to splice. :happyno::happyno:
The Aussie electricians I used to work with called them Choco-blocks. Apparently, they look like some type of Australian chocolate bar. My shop calls them Eurostrip terminal blocks, and we use hundreds of them each year for LED lighting.
We also use Wago Lever-Locks. We've used them on several cruise ship projects; the ship electricians love 'em. They will throw you off the ship if you try to use wirenuts though
I don't understand the hate for wirenuts though. They do need to be properly sized and installed, but that really goes for anything. I've also had no issues with stranded conductors and wirenuts. Just use quality materials, and not the knockoff crap wirenuts.
SceneryDriver
You can cut them to however many way you require. Even if it's only one.Yeah, those are very practical when you have multiple conductors to splice. :happyno::happyno:
Solder and tape![]()
I prefer Ideal for all wire connectors. I never liked any 3M wire connectors. You can call me a brand purist if you like.
Do you have a problem with that?
I only use Buchanan WingTwist reds. I’ve never liked the soft plastic of the Ideal brand reds, but I use the ideal “gator” nuts (orange/blue).
I also like the 3M tans.
Yes, I do as a matter of fact. How do you splice 5 or more wires together with those inferior connectors?
for the small wires, at least. If you are joining 5 number 4s then I guess you need another way...
We used din rail terminals. That was what was expected.They have their place, but for general termination and splicing using our common methods of wiring, boxes, and devices, they would be quite difficult.
They work well in control panels and similar applications where wire nuts are generally not acceptable.
http://www.sprecherschuh.com/ecatalog/get/Section_N.pdf
mini bus bar type of solution... the uk sells these busbar thungies that slip in the one side... joining all of them into one voltage, and then you use only the other side...
or you get an insulated buss bar and do the same thing with it... like we use in our lights here...built into the ceiling rose...
But, best is the WAGO..lol..
They serve us well here in North America and that includes Canada and Mexico.
I don't see why they would be difficult. Not that we very often use them for permanent connections. Most fittings here, switches, lights etc. have brass terminals with grub screws and capacity to terminate extra switch wires for example.They have their place, but for general termination and splicing using our common methods of wiring, boxes, and devices, they would be quite difficult.
With respect, I disagree, I have used both.I get the British way of doing things. But it's completely incompatible here. We use larger boxes instead of those crazy ceiling rose things.
Bottom line, twist on wire connectors are just as reliable as a terminal block when installed correctly with far less labor and take up less room.
