stickboy1375
- Litchfield, CT
ugh. that's so trashy. :happyno:
No way, all the cool people are doing it, vertical is so 80's...
I like my cover screws vertical when practical, but never know what to do when device is horizontal.
Why vertical? Horizontal is so in right now...And it doesn't matter which way you install them, because the painter doesn't care...
I place all my wire nut splices in cases of prefabricated amulite, surrounded by hydrocoptic marzle vanes. They are then encased in solid lead, and placed in an air-conditioned compartment with a three back-up power sources to prevent overheating. A miniature Ansul system and fire sprinkler system are also installed as fail-safe fire protection means.
All protected by an electronic alarm system, utilizing a T5 reporting phone line. An 24/7-security firm's armed guard is placed at each splice location. In addition, I fly over the entire site every day in my personal helicopter.
I'm going to start using "pop rivits" instead of screws to hold on the cover plate, then it will not have a slot and the painter will just have to deal with it, I just don't care any more. Hope I never have to come back and trouble shoot any thing.
That was such an easy thread high jacking, just say ground up or vertical cover screws and everyone chimes in.
Why go to all that trouble when you can just use Wago's instead?
They don't come with a drain hole like the greenies.Why go to all that trouble when you can just use Wago's instead?
I hope you realize my posts were just for fun.
I was told a while back (before I started in the apprenticeship program), that when making joints in a wall mounted j-box, the wire nuts must be positioned so that no water could collect in the wire nut should there be a leak in the roof, etc... I was also told that this was in the code. Altough I feel that this is good practice, and always make my joints so that the wire nuts are facing up, I cannot find in the code book where this is mentioned. 110.14(B), and 300.4 are where I would think this info would be, but no luck. any comments or ideas?
The wirenuts were facing down in this box and the problem had NOTHING to do with the splice, it was the insects.Damn there were a lot of spiders on that job.
The wire nuts were originally installed pointed up. The spiders turned 'em down so they could lay their eggs in 'em. :lol:
They were big spiders.:jawdrop:
The picture a few posts ago was of a "Bell Box" They keep water out, but if it can get in, it stays in. I always drill a small hole in the bottom of the box, or as the NEC states, "arranged to drain"
