- Tennessee NEC:2017
- Semi-Retired Electrician
I need to install an occupancy sensor in a garage. The problem is the switch for the lights is in the house and not in the garage. I use a lot of Lutron RF switches with PICO remotes. Do they have an occ sensor that works like a PICO that I could use along with replacing the hardwired switch with an RF switch? I have used both Casetta and just the RF switch. The RF switch is basically the same as a Casetta without some of the options that Casetta uses. I see some things offered by Lutron but they are confusing to me there are so many. What do some of you guys use for my desired application?
