I find that Lutron has a much more reliable wireless switch and some don't require a neutral at the switch.
If it's just a switch you need and it's not going through a hub or similar, I would go with Lutron's RF switch. It can be used in 3-way, 4-way, etc. situations. It does require the PICO wireless remote switch. You just replace a regular switch with the RF master switch and place the PICO where you need it. You also need the PICO mounting bracket to mount the PICO remote to. You then put a decora plate or Claro screwless wall plate and it looks like any decora switch.
https://www.1000bulbs.com/product/117305/LUT-PD5SDVWH.html
If you want/need a dimmer or are running through a hub or smart switch, the the Caseta line from Lutron is what you want. It's the same switch as the RF but does a few more things.
https://www.1000bulbs.com/search/?q=caseta+wireless+switch
