- Massachusetts
Carefully drill a 3/8" hole into the top side of the conduit about every ten feet and then empty a can of expanding foam into each hole, rattling curred.:wink:
No - first time I went to it - it said it had 'been removed'Mark, did you see the video in my post above?
Except for one thing, EMT is inside the concrete wall from main panel to disconnect switch, and EMT runs throug the top of electrical panel and comes down from the ceiling at elevator room, everything is inside concrete walls.Carefully drill a 3/8" hole into the top side of the conduit about every ten feet and then empty a can of expanding foam into each hole, rattling curred.:wink:
Very amazing how the wires move, I send one video to my customer and explained him that the cost of ordering the twisted wires, will be more expensive than the previous bid, now I waiting for the decision they will take, thanks everybody for all your help on this issue.No - first time I went to it - it said it had 'been removed'second time it worked
- The cable tray one is pretty apt... But extreme...
I think this one is closer. The conductor on the left.
Bob - have you done this? I assume you megged it? And used a rare earth magnets and a vaccum to draw chips away from the hole while drilling? With or without the conductors? Energized or not? Is there a listed/approved duct sealing foam? Once filled - is it still a 'raceway'?Carefully drill a 3/8" hole into the top side of the conduit about every ten feet and then empty a can of expanding foam into each hole, rattling curred.:wink:
Add the binding tape... And 5 gallons of soap....Very amazing how the wires move, I send one video to my customer and explained him that the cost of ordering the twisted wires, will be more expensive than the previous bid, now I waiting for the decision they will take, thanks everybody for all your help on this issue.
I tried to check out your video and it said it was no longer available.Mark, did you see the video in my post above? I feel it closely demonstrates the effect of AC cables in pipe.
Bob - have you done this? I assume you megged it? And used a rare earth magnets and a vaccum to draw chips away from the hole while drilling? With or without the conductors? Energized or not? Is there a listed/approved duct sealing foam? Once filled - is it still a 'raceway'?![]()
