Excellent point ! Never thought about that225.30 would likely require a MWBC.
Welcome to the Forum.![]()
Only if this "Bar" is considered a separate structure. If it is on a patio considered a part of the main structure, 225 doesn't apply at all.225.30 would likely require a MWBC.
When one reads 225.1 that may well be debatable.
I don't necessarily agree with that statement. Some may be separate structures but not all.So another words all outside BBQ islands are separate structures and need a local disconnect.
I would share neutral with little hesitation unless there were going to be some giant sized, industrial blender at the bar. Then I would still run a MWBC and add a dedicated circuit for the blender.It needs lights and outlets.. I was gonna run two circuits so the outlet is dedicated.. Can I pull a 3 wire and share the nuetral? Or should I pull two seperate 12-2s?
What's mwbc?
What's mwbc?
I wouldn't be too hard on anyone over an acronym that is more of an acronym for electronic communications purposes then it is an acronym for the trade.Umm....are you an Electrician? meaning nothing by it....Just Inquiring is all.
No, they are not generally used in the NEC. But they are often used by people who use the NEC and hate to type.Masterthenec, yes I am. Licensed as well. I'm sorry for not knowing acronyms, are acronyms used in the nec?
@kwired.. Thank you.
