Wiring methods for recessed LED lighting
WRC
New member
United States
I am a lighting designer and stuck on this after looking in NEC and googling. Gut remodel - to studs and joist - of a kitchen. 10 recessed low voltage fixtures - new work - happens to be a Nora NL-301 - with a transformer - and I'm installing in joists to be above drywall ceiling. With difficulty the fixture design does allow removing the cone - 3 screws - with attached junction box and transformer and snaking that through the opening if ever needed to service transformer, as I believe is required. What wiring method is acceptable? (under NEC 2003) I ruled out MC because it has to be supported withing 12" of fixture, which does not allow enough slack. FMC seems about the only choice in this situation. 1/2" is too stiff and big to allow removal so was planning on 3/8", but a struggle to pull and it has to be more than 6'. I might be able to locate one junction box within 6' of all fixtures but tight, not pretty, and with 8 fixtures, a big big box. Other option I considered was EMT to within 6' and then coupling for 6' whip of 3/8" FMC.
What am I not getting? Thanks.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
