sfav8r
- San Francisco Bay Area
We have run into this once again with a 36" Wolf Range. Under the electrical specifications it says "The stove circuit should have it's own 15a circuit breaker." It doesn't say the word required, but it also doesn't just say they recommend it. I finally called them and they said "We recommend that all our products are on dedicated circuits." I told them I have no problem with them RECOMMENDING it but that when they use the word SHOULD it means the same as SHALL and shall means we need a dedicated circuit...which in this case is three floors down as this is a condo. So personally I'm tired of manufacturers having "requirements" like this. I am recommending that the client select a different manufacturer. What do you guys do? I suspect if I just ignore it the local inspector will not read the requirements, but then again Wolf stated flat out that the warranty would be void if the stove isn't on a dedicated circuit. Their position is that the igniter generates noise on the line and is a problem for other products and that the stove electronics are very susceptible to noise from blenders, etc. To me it jusst sounds like bad engineering. There are lots of stoves that don't have this requirement.
- :thumbsup:
