No, they just need to ensure the contractor they are hiring is qualified, and in the OP the EC they hired obviously was not.
I understand that - I think that is a bigger issue with their liability insurance than with OSHA and safe work practice (but I could be wrong) My point was if a mechanic was injured while working on your car, especially when working on it in their own facility, why should anything be the car owners fault, outside of the really bizzare possibility of the owner intentionally causing the injury somehow?Which in the OP's question was obviously not the case.
You have it 100% backwards, if you take your car to the repair shop they don't let you in the garage area under the car (Or are not supposed to anyways, I usually ask if I can see what they found) because if the car falls on you they could be held liable.
No you are not qualified, if you were you would have been wearing the proper PPE and would not be burnt.
How is protecting employees from workplace hazards wrong exactly?
No it won't, however someday you will be out of a job if you don't comply. EC's all over the world have been changing the way they do work and approach safety (Including many menbers here), those that do not will start to lose work for not being qualified. Will homeowners ever care? I doubt it, but commercial and industrial customers already do care.
Who is the employer??
the EC owner, or the property owner ?????
simple question, not a simple answer.
Who has 'control' over the person doing the work and the methods they use to accomplish the task?
In the cases where the property owner has a contract with the Electrical Contractor (EC), the person performing the labor is most likely an employee of the EC. The terms of the contract spell out, usually implicitly although sometimes explicitly, who has 'control of the worker'.
In other situations the property owner may contract for labor only, like a temp agency, in which case they probably retain 'control of the worker'.
zog, the test switch is installed in the switchgear and it removes main breaker and the generator breaker is installed. Is this considered racking a breaker? i hope that helps describing it. thanks.
Don't get me wrong I am in no way discouraging safe work practices, but when someone hires a so called professional that is what they expect If that is not what they get that is another problem
That is why this thread was started in the first place, the OP was concerned about the EC not being in compliance.An industrial place that has their own in house electricians that hires a contractor to come do something has somebody that knows if they are doing something wrong - they can certainly tell them to comply with the safety rules or leave.
I don't see how that has anything to do with the topic?? But this is the reason the dentist has medical malpractice insurance.Same goes for if you are a patient for the dentist. If they are not using proper safety procedures - does the average person even know what OSHA standards may even apply to what they are doing? Before you can even begin to have a clue as to what safety precautions need to be taken you have to know what the hazards are.
Sure it does, OSHA does nto write any standards, they just write a legally enforcable version of recognized safety practices. In this case that is the NFPA 70E, the first version of the 70E was released in 1979 and adopted as OSHA's final rule and ESWP's (Subpart S) in 1981, OSHA revisions have followed 70E revisions ever since. The NFPA was founded and funded by....you guessed it, insurance companies.I understand that - I think that is a bigger issue with their liability insurance than with OSHA and safe work practice (but I could be wrong)
Again, not following you here, no one is sugesting the car owner would be at fault???My point was if a mechanic was injured while working on your car, especially when working on it in their own facility, why should anything be the car owners fault, outside of the really bizzare possibility of the owner intentionally causing the injury somehow?
I'm sure the line between employer and contracted party has been blurred by lawsuits in the past. Again I am not condoning unsafe work practices, but being held responsible for the negligence of someone you contracted (not employed) is just not right IMO.
Exactly, that is the problem, they need to ensure the EC meets the requirements from the 70E that I posted.
Try this example. You install an in ground pool in your back yard with no fence around it. You wake up one morning to find a neighbors kid floating in it. Do you think you could be held liable for that? You bet, which is why many places require you to have a fence around a pool.
Both the employer and contractor could be held liable if they are found negligent, it is all about what was done to protect the person. The 70E is the standard for electrical safety in the WORKPLACE (Not just for employees) and is clear about the responsibilities of the owner. The employer of the electrician has his own responsibilities to protect his employees (Training, providing PPE, etc...)
If the property owner does what the 70E requires, and the employer does what is required of him and the electrcian ignores all of his training, decides not to use his PPE, and gets hurt, there will be no one to blame but himself.
I don't see how this is confusing or how anyone can think it is wrong, these rules are all about preventing deaths or serious injuries of workers. However there are many senarios to cover so it gets a little complex to cover things like some moron that ignores the rules, gets hurt, and tries to place blame on others, which happens all the time.
But the fact is, when you are in that burn unit, being lowered into a tub of bleach with a nurse stading there with a brillo pad to "debreed" you for the 3rd time that day and for the 80th day in a row, who cares who's fault it is?!?!?? I promise you that would be the last thing on your mind.
No, I am mostly looking at this froma business side. Companies that do not follow 70E are going to be left behind as more and more industrial and commercial companies will require proof of 70E compliance for an EC to even bid a job. For commercial properties you will see this requirement not come from the manager of a taco bell but rather from taco HQ via thier insurance companies.You are looking at it totally from the safety side - nothing wrong with that.
No, I already stated I don't see this being an issue with residential customers, but that does not mean the EC does nto have to follow the rules.Is every US citizen supposed to be familiar with 70E? It would seem to me that only if they have to deal with electrical hazards in the work place they may even have a chance of having heard of 70E. There is probably other similar publications for other lines of work none of us have ever heard of. If the hazards covered by those publications exist then we should all know about them just like 70E.
Someone else is going to have to take over this discussion as I am off to the Keys in 10 minutes. I will be out on a boat most days and won't be around here but there are plenty of other members here that understand what the requirements are so tag guys, you are it.
I hope I answered Jimbos question from the 1st post![]()
I fully agree with most of what you said. The part about commercial properties and Taco Bell is some of what happens. I have no problem with that. Just because HQ and their insurance requires them to follow 70E - who is there that knows and understands 70E to relieve them from their job if they are not in compliance?? If the contractor signs paperwork stating that they do practice 70E requirements and then one of their employees is injured because of non compliance - why is that liability on Taco Bell or its insurance? The contractor or his employee is the one not doing their part.
Just because HQ says it has to be done, just how is someone at the local restaurant supposed to have the expertise to know if it has been done, or done correctly?
The local manager of the restaurant will not have any clue about electrical safe work practices, proper use of fall arrest equipment, etc.
I understand the reality, I do not think it is always right. Makes a lot of sense to call yourself an electrician, roofer, asbestos remover, etc. and then sue a property owner for your own negligence.In the US the property owner has always had some amount of exposure to liability.This goes for electrical work, roofing work, asbestos removal, even painting the stripes in a parking lot. If a worker/employee is injured they have the right to sue everybody that might be involved, even remotely, in the incident.Where do you see that implementation or enforcement of NFPA70E requirements increases a property owner's exposure?
Settlements paid out total nearly $175 million. The defendants include local TV station WPRI, JBL, Anheuser-Busch, Clear Channel, and Home Depot.
There are two reasons...first we have way too many lawyers with nothing else to do and second because we are making it so we are no longer resposnible for our actions...it is always some one else's fault.Don't get me wrong I am in no way discouraging safe work practices, but when someone hires a so called professional that is what they expect If that is not what they get that is another problem, but why are you liable for technical neglegence that you may have no idea what is correct procedure?
The irony is that the same guy who's jumped all over when changing a bulb is the guy who five minutes ago was expected to climb a pole and tie into the unfused PoCo service drop.
But the rules allow that, so it is OK.
No where does it say that.I thought it was just POCO employees that can do that. Somehow they are immune to arc flash or shock hazards if it is below 600 volts.
NESC 2006- Effective as of January 1, 2009, the employer shall ensure that an assessment is performed to determine potential exposure to an electric arc for employees who work on or near energized parts or equipment. If the assessment determines a potential employee exposure greater than 2 cal/cm2 exists (see Neal, Bingham, and Doughty [B59]), the employer shall require employees to wear clothing or a clothing system that has an effective arc rating not less than the anticipated level of arc energy. When exposed to an electric arc or flame, clothing made from the following materials shall not be worn: acetate, nylon, polyester, or polypropylene. The effective arc rating of clothing or a clothing system to be worn at voltages 1000 V and above shall be determined using Tables 410-1 and 410-2 or performing an arc hazard analysis. When an arc hazard analysis is performed, it shall include a calculation of the estimated arc energy based on the available fault current, the duration of the arc (cycles), and the distance from the arc to the employee.
EXCEPTION 2: For secondary systems below 1000 V, applicable work rules required by this part and engineering controls shall be utilized to limit exposure. In lieu of performing an arc hazard analysis, clothing or a clothing system with a minimum effective arc rating of 4 cal/cm2 shall be required to limit the likelihood of ignition.
Compliance with arc flash PPE requirements is as big a deal with 'utilities' as it is with 'companies'.
This is a little old, but it seems real close to NFPA70E:
