busman
- Northern Virginia
- Master Electrician / Electrical Engineer
If low DC voltages are really so dangerous, there should be thousands of dead stick welders all over the world.
What kind of battery are you talking about? A series connected bank or just 12 volts? I've changed or moved about a trillion 12 volt batteries, lived and worked on off-grid 12 volt systems, never gotten a shock from 12 volts.If you guys don't know how easy it is to get shocked from a battery then you just don't have the experience. And It is just as easy to deliberately shock someone with 120v or 1v. If you don't believe that, that is just fine.
It is hard but not impossible to harm yourself with a 12 Volt circuit.
For instance, if you had a cut that opened the skin, you would no longer have the skin protecting you. Skin tends to have a fairly high resistance. The tissue and blood under the skin does not.
not necessarily. the skin resistance would basically be half what it otherwise would be. and if the other point of contact was damp or bloody, the skin resistance there could be much lower than normal.But you would need TWO cuts wouldn't you, one for entry and one for exit?
I am so very glad to hear that it is "just fine" that I don't believe you. Show me a single documented case of someone being shocked with a 1V battery. You can probably be shocked by a 6V battery if the contacts are close enough together that you can touch them both at the same time with your tongue; I'll give you that. That's how I check 9V alkaline batteries.If you guys don't know how easy it is to get shocked from a battery then you just don't have the experience. And It is just as easy to deliberately shock someone with 120v or 1v. If you don't believe that, that is just fine.
Ok, I don't believe that.If you guys don't know how easy it is to get shocked from a battery then you just don't have the experience. And It is just as easy to deliberately shock someone with 120v or 1v. If you don't believe that, that is just fine.
Perspiration. Ask a mechanic. Then we can get into the intentional ways like jumper cable jaws. It doesn't matter, it's just hard to tell if the other buddies here like debate club or are really that dumb. I think it's a bit of both. I have 2 plane tickets for the "prove it" kids.It is hard but not impossible to harm yourself with a 12 Volt circuit.
Many times I have simultaneously touched both poles of a 12V automotive battery with many hundred available amperes. I never felt a thing.
I have a hard time believing that and never ever seen or heard of that happening and I've messed with batteries a lot more than the average bear I'm sure. Between living off grid with batteries, all my equipment, all my poor connections I procrastinate fixing, and being too cheap to get batteries for everything so I'm always moving batteries around...... For one thing the battery only makes hydrogen when it's being charged,. Even Then I highly doubt you would get a high enough concentration to ignite.When on my back under a dashboard, sweating, and my forehead touching the steel, if my hand touches a +12 volt wire, I can feel it in my head enough to make me jump. Two dry hands on the car battery, nope.
Arc flash of a vehicle battery is bad when the spark at the terminals ignites the hydrogen/air mixture. Seen it too many times to say never! Taken employees to the emergency room because of it. You know, journeyman sits in truck that won't start, has apprentice wiggle battery connections while he turns key. Blam. Off to the ER after a quick rinse. Sometimes they just explode when trying to start. Lucky, the hood is usually closed then.
Wish I had taken a picture of what happened in my Dad's garage. He put a 12V battery on the battery charger and left it overnight. Next day he went out to the garage to disconnect the charger. What he found was the shell of the battery with the top blew off and parts of it stuck in the ceiling of the garage! Would have been bad if someone was standing over that battery, or even close to it, when it blew!!!I have a hard time believing that and never ever seen or heard of that happening and I've messed with batteries a lot more than the average bear I'm sure. Between living off grid with batteries, all my equipment, all my poor connections I procrastinate fixing, and being too cheap to get batteries for everything so I'm always moving batteries around...... For one thing the battery only makes hydrogen when it's being charged,. Even Then I highly doubt you would get a high enough concentration to ignite.
Souods like a sealed battery that had some sort of issue or charged at too high a rate.Wish I had taken a picture of what happened in my Dad's garage. He put a 12V battery on the battery charger and left it overnight. Next day he went out to the garage to disconnect the charger. What he found was the shell of the battery with the top blew off and parts of it stuck in the ceiling of the garage! Would have been bad if someone was standing over that battery, or even close to it, when it blew!!!
Lead acid batteries do occasionally have explosions; my dad once had one blow the cover off while he was close to it. Luckily he had glasses on that kept the acid out of his eyes.I have a hard time believing that and never ever seen or heard of that happening and I've messed with batteries a lot more than the average bear I'm sure. Between living off grid with batteries, all my equipment, all my poor connections I procrastinate fixing, and being too cheap to get batteries for everything so I'm always moving batteries around...... For one thing the battery only makes hydrogen when it's being charged,. Even Then I highly doubt you would get a high enough concentration to ignite.
Just a regular lead acid with caps. His old charger only had a choice of 6V or 12V, no timer or anything.Souods like a sealed battery that had some sort of issue or charged at too high a rate.
Puncturing the skin with loose strands from a high conductor count, fine stranded, cable could take care of one or both ends too.Perspiration. Ask a mechanic. Then we can get into the intentional ways like jumper cable jaws. It doesn't matter, it's just hard to tell if the other buddies here like debate club or are really that dumb. I think it's a bit of both. I have 2 plane tickets for the "prove it" kids.
@LarryFineIf I "must" (separate discussion) connect a device while the circuit is hot, I also connect the hot conductor to its terminal first and the EGC last, especially with narrow-body 15a switches. Their screw terminals are particularly close to the metal yoke.
That way, I know where the hot is, I don't have to divide my attention, and I have control of it while connecting the rest of the wires. I don't risk getting shocked if the hot inadvertently touches the yoke because I always hold the yoke with my pliers.
I don't want a fault arcing in front of me even if I won't get a shock from it (which is itself debatable because half voltage (or more) could theoretically appear at the fault point).
You'll get an arc. There's no meaningful likelihood that the breaker will trip.@LarryFine
Question for you, if you did land the ground first and we’re holding the grounded yoke with one hand and had the hot wire held by the insulation firmly and that hot hit the yoke, the ckt should trip
No. You haven't described the body touching two points at different potential.but could you also get shocked by holding the yoke with one hand at that same moment?
