Ragin Cajun
- Upstate S.C.
The electrical contractor for an apartment complex I designed called regarding the inspector hitting him hard on working spaces. I think the inspector is a bit out of line.
The inspector has no issue with the disconnects for the EWH located in a closet (typical installation).
But, the inspector rejected the ones for the condenser units outside. The contractor said that the inspector has failed all disconnects with line sets that do not come straight out from wall to unit because of the 36" rule as stated in code. He said be does not care about the condenser, rather he says a person has to be able to access the disconnect without interference. [Whatever that means.]
I see more "working space" here than in most installations I have seen. I don't see why the installation is being rejected.
Take a look at the three pictures and tell me what you think. As you can imagine, a "fix" will not be simple and expensive to boot.
I haven't spoken to the inspector yet. Want a good basis first. From past experience with this inspector, he is quite hard nosed and opinionated.
Thanks!
RC
Thanks!
RC
