Mustwin351
- Texas
Is it just me or is that receptacle completely missing a device box on the wall?
However I am having a small issue with someone in a building I am responsible for after they do their contract.
I do not believe that the out of state guys he has even have Michigan licensing.
I have no clue what your problem is with the first photo. Boxes maybe not all the same height? That is not an NEC issue.Where does it say in the code to leave a few strands to stray in free air outside the terminal?
Do your friends also do this or this?![]()
Sent from my SM-N910V using Tapatalk
I terminate stranded wire all the time just like the picture. I don't see any strands sticking out and I don't see a problem.
How are you responsible for this building when someone else has the electrical contract?
Whoever permitted the job is responsible for the work performed, looks like more than just electrical work so there must be a GC involved with the EC as a sub.
Most states do require some sort of warranty on new construction type work.
Who drew up the plans and specs for this job. They could have put any sort of requirements they wished in the job specs.
Are you hired by the owners to oversee this job in any way?
Look closely the box is dangling at a 45° and there is a air gap between box and drywall. And yes what the hell no tape measure or level or chalk line? This is repair and they were straight and level before you touch them they should be level when you done. Not a code issue on the level just a hack issueI have no clue what your problem is with the first photo. Boxes maybe not all the same height? That is not an NEC issue.
Second photo - the short tail of conductor at each terminal is very likely the result of stripping the conductor further back from the end but only enough to make termination and leaving excess insulation past the end of the conductor. IMO this was a wise thing to do vs stripping just the last 3/4 inch of insulation off the conductor if you are going to terminate stranded conductor under the screw terminals. It prevents the end of the conductor from splaying out when you tighten the screw terminal. The end of the conductor is 3/4 to an inch back inside the insulation and it is not going to short out on the box or anything else.
If there are no prints or other specifications then all the installer needs to do is pass inspection for the most part.Yes I'm hired to oversee this job by the owner. There's no prints and I am the warranty LMAO another reason I'm gonna straighten this all out
Agreed finally someone else who sees the point. So it would appear that this is a gray area issue and difficult to challenge especially when it's a cheap dollar driven low quality ecAs much as I avoid stranded wire, when I have to I do it that way too. EXCEPT I use that short tail to twist the stripped strands tightly then wrap and tighten the screw. Then I cut the tail off with my cutters as far from the screw as possible but not extending past the live parts on side of the device.
I also agree that when pigtailing, use solid for the pigtail.
-Hal
My reasons would be workman like manner and that it's not a listed installation for that device yoke? Any more blatant codes? Or proof of this as a poor method?
It is a gray issue area regardless of how low quality the EC may be.Agreed finally someone else who sees the point. So it would appear that this is a gray area issue and difficult to challenge especially when it's a cheap dollar driven low quality ec
I am the lead electrician and this is a large insurance claim. The GC has its own EC and not to mention I am already overloaded with work. I maintain and repair all the electrical in the entire facilityHow are you responsible for this building when someone else has the electrical contract?
Out of state down south guy is his only experienced guy. Which in my experience never have I met or seen southern electricians with much quality. PM does no physical work and doesn't appear to train or have skills of his own. Then all the work is done by apprentice with very little experience and oversight. Instead of removing old work boxes and spanning new or screw mounting new ones he is attempting to hack them in areas where old Wall was removed and new installed. This reminds me of how the as my father used to say "the trades are going to ....."It is a gray issue area regardless of how low quality the EC may be.
Appears you don't like him for some reason, yet haven't given us anything to definitely say he is totally incompetent.
It's an insurance job. Everything must be repaired to original specification. They don't have a print. The owners satisfaction is the sign off and I'm sure that no warranty exist in reality. It's a rush job, get it done, but I don't believe you need to toss all quality out the window.You said you have no prints. Do you have specs? Do you have a contract? If you dont have any prior documentation you have established that you don't know what you are doing. Expect the contractor to follow your example.
Sent from my SM-N910P using Tapatalk
Yes I learned a lot. Also I learned that crimping forks on is not listedI understand your frustration with some of the work. However you didn't start out by telling us all the facts. You wanted us to tell you that using stranded wire around a screw was a code violation and also not a listed method.
we were just pointing out that it's fine/legal/listed to terminate stranded wire this way.
Where they are from has nothing to do with what they know or how good of work they will do. There are many that participate on this site that are from somewhere down south that are very good at this trade, and I am sure there are hack electricians within your own city that don't really know as much as they maybe should. If they are passing inspections they must not be that bad.Out of state down south guy is his only experienced guy. Which in my experience never have I met or seen southern electricians with much quality. PM does no physical work and doesn't appear to train or have skills of his own. Then all the work is done by apprentice with very little experience and oversight. Instead of removing old work boxes and spanning new or screw mounting new ones he is attempting to hack them in areas where old Wall was removed and new installed. This reminds me of how the as my father used to say "the trades are going to ...."
