Re: Wye-Delta issues
Rattus,
thanks! what about when you lose one transformer, not the center-tapped, completely with no remaining connections to the other 2 transformers? isn't that an open wye - open Delta and hence there is no changes in the secondary voltages? or it is still a single phase, no neutral, with the same voltages magnitudes as discussed earlier, with case of a blown fuse?
Rattus,
