I have been told by the chief electrician that a three phase transformer being fed a wye on the primary can be changed to a delta primary. I believe this is done by rewiring the transformer connections inside the transformer as I recollect him saying to me.
I want to do this because I am replacing a wye-wye 3 phase aerial distributed ground mounted 208/120 volt 3000KVA transformer with a 3 phase pad mounted 208/120 volt 3000KVA transformer.
I don't want a wye-wye configuration because there are too many harmonics and unbalanced loads. I want a delta wye configuration.
Comming from the substation to my 3 phase 300KVA pad mounted transformer is a 3 phase 12KV wye primary distribution.
