JFletcher
- Williamsburg, VA
The apparent moisture present* would concern me as a HO more than half of that 2x10 or 2x12 cut away... even if there is a load bearing stud over the center of it, it's sitting on a bottom plate which is on the rim joist and band board. Probably a single story house, and I'd bet the wall above is fine.
* There appears to be mold growing at the joist/subfloor intersection, and the discoloration of the subfloor seems to indicate moisture.
No reason to shy away from the job because of that cut... it's obviously existing and nothing that can be pinned on the OP, who apparently didn't get the job anyway.
