Dennis Alwon said:I have always thought that bonding of doors and windows was a bit much. I have not seen anything in 2008 that supports the need to dond doors and windows.
What's donding? You have 10 minutes to fix itradiopet said:Hey Dennis......Is "donding" a new requirement in 2008...thehehehe
lol....you said "dond windows" so I figured you knew something I didn't about Donding...lol.....Dennis Alwon said:What's donding? You have 10 minutes to fix it
No, it's not new but there have been many changes. What wording supports bonding doors and windows? >
M. D. said:I was just curious ,.. why the window frame and door frame in the 2008 graphic are not bonded??? Just artistic license? Or were they left out do to a change ???
2008
lol...I've been called worse.....Much Worse...in fact just last week I was called.....well.......nevermind because he had an excuse, I failed his inspection.Dennis Alwon said:I missed that and I tried to edit but it said I must contact the administrator to change it. Dang I wanted to change it and say you were nuts.
M. D. said:Paul ,the frames appear the exact same in the 04 image,.. I know some have always thought that the door and widow frame did not require bonding ,..I wonder if Mike Holt is now of the same opinion,.. I see no reason for the change otherwise.
frizbeedog said:M. D., They must have remodeled that house in the drawing and installed vinyl doors and windows. :smile:
ryan_618 said:The reason it was removed is because Mike wanted it removed. I was part of the discussion.
frizbeedog said:Does 680.26 (B) (7) cover the bonding of those doors and windows?
Seems like it to me. What do you think?
2008
