aftershock
- Memphis, TN
LarryFine said:Yes, and you could see that it was a nail-on and where the plastic nail brackets had been cut away.
Why didn't he just use a 3-gang old-work box?
Alot of times if we are installing switch boxes and they are near wall studs, instead of using an old work box, we will cut the nail holders off of a nail on and then secure them to the wall stud with sheetrock screws. To be honest from experiance, this method has proven to be better support than a cut-in/old work box which relies on the sheetrock only, as a support.
Use a 2 gang cut-in/old work box to wire a dryer (10/3 with ground). Hook up your dryer rec and start pushing back to the box so you can secure it. Watch it shove the box through the sheetrock.
Now, cut the nailers off a 2 gang box, secure it to the wall stud and do the same thing in the previous paragraph. The box wont move.
