wasasparky said:If the screws are up in the corners, I believe it is code compliant. See post #73.
I'll admit it....I agree.:smile:
That's the way that I read 314.23(B)(1).
steve
Right in the middle of the box's left side.wasasparky said:I did not see the episode to see exactly where the screws we placed in that install...
New?peter d said:Has anyone seen the show "Ask This New House?"
I've met Tom Silva. I mentioned that would love to join them. He said "You and about 10,000 other guys."peter said:They need an electrician to join that elite group. Is anybody near and willing?
LarryFine said:I've met Tom Silva.
I just googled them, they look pretty nice for old work uses.acrwc10 said:I'll keep a handful of "smart boxes on the truck because they come in handy so often, even on new installations before sheet rock.
VoltageHz said:What special feature do you get out of them in new installations vs. typical nail on boxes?
That's a good idea!MF Dagger said:Throwing them in between two studs where you can't get a lineman's or a hammer at the nails. I hate the boxes that secure to the front of the studs so I use a smart box or two on new houses usually.
220/221 said:The Smarter Box.
25 cents and no special stock.
I know that somebody will make the point that the listing is void when I pull out the nails and cut off the tabs.:roll:
PS. I saw another brand of Smart box in the EC mag yesterday. It is adjustable but the screqws are NOT 1/4 from the back of the box so I guess that, even though it's UL listed, it's still illegal.
So you are saying that all those old work plastic boxes are not allowed to be used for old work purposes (unless you break open the wall within 8" of the cutout and support the wire)?al said:Since there are no cable clamps in the box, the nm cable must be stapled within 8" of the box, with no execeptions for fishing, which leads me to believe you cannot use this box.
VoltageHz said:So you are saying that all those old work plastic boxes are not allowed to be used for old work purposes (unless you break open the wall within 8" of the cutout and support the wire)?
iwire said:Whatever floats your boat, I like using the right stuff for the job and then charging for it. :smile:
I see. By cable clamps you mean those little plastic flaps in the back of the box, correct? I see the box you have pictured has flaps that come completely out instead of hinging like the old work boxes. Seems like a weak difference, but code nonetheless.al said:All the old work boxes I have seen have cable clamps so the wire can be fished to the box.
Al
