svh19044
- Philly Suburbs
For plaster and wood lathe I do it without power tools. In this case the plaster was so brittle if a hole saw bit would hang up in the slightest half the cieling would fall down. So i scored around the plaster with my utility knife and chipped out the plaster leaving the wood lathe. Then i take a drill with a 1" paddle bit and drill the perimeter of the lathe and snip it out with my dikes. Takes extra time but the holes were very good and clean and no cracks in the cieling. In my opinion if you use power tools on very brittle plaster your pressing your luck.
The room was being renovated and only the plywood floor was down so the owner said don't worry about making a mess so i did:lol:
I would suggest you give the carbide grit hole saws a try (along with the dust bowls). Use the ones that have no deep cut teeth, it's carbide all around. Again, go with the Milwaukee recessed light hole saws (or similar style). They are excellent for lathe and plaster holes, and I can't imagine ANY hand cutting doing a better/cleaner job.
http://www.milwaukeetool.com/accessories/drilling-accessories/hole-saws/recessed-light-hole-saws
