E.M.T. good for ground
lendog
California
Hi does anybody know were in the code book it says how many amps e.m.t. is good for ground. Someboddy asked me where in the book it says it, but I cant find it.
iwire
Massachusetts
Nowhere in the NEC is it limited by amps.
EMT is allowed as an EGC per 250.118.
Jim W in Tampa
Tampa Florida
iwire said:
Of course not, it will never work. :grin:
No Bob i did not say that.It might and then again it just might not.All we need is 1 set screw that wasnt tightened or conduit that got hit and came apart.Then we have something worse than no ground at all.
iwire
Massachusetts
All we need is 1 wire-nut that wasn't tightened or wago that got hit and came apart.Then we have something worse than no ground at all.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
Ahhhh but in Jim's case you still have the EMT for the ground.
roger
Fl
Retired Electrician
Jim, consider this, a properly installed metallic conduit recognized in 250.118 is a better EGC than a properly installed insulated conductor.
What is the common denominator in that statement?
Roger
roger
Fl
Retired Electrician
But if the same installer did both, how would you guarantee either ones quality?
Roger
peter d
New England
As I said the last time this issue came up, we always splice with 100% accuracy but we somehow forget to make sure our raceways are mechanically sound. ;)
iwire
Massachusetts
I was taking NM jobs, are your suggesting we should always run redundant grounds? :grin:
By the way, run an EGC, don't run an EGC I really don't care. :)
Sometimes I do, sometimes I do not, depends on many things. :smile:
What I try to do is get people to think about the reasons why they do the things they do.
Don't just do things because you have always done them, or that was 'how I was taught', or someone said it was better, ask yourself why. :cool:
Dennis Alwon
Chapel Hill, NC
Roger
That's why you bring in a third party and pull another ground wire just to be safe. :grin:
roger
Fl
Retired Electrician
But Peter, if the conduit is not mechanically sound, what's protecting the EGC inside of it? ;)
Roger
iwire
Massachusetts
:grin:
Can we also require tests, send emails and have meetings about the grounding for each circuit? :D
roger
Fl
Retired Electrician
This reminds me of security when working inside a Casino.
They send a guard to watch you and another guard to watch him and all the while all of you are being watched on camera.:)
Roger
