rattus said:Please open the attachment which is a partial phasor diagram of a 120/208 wye. (Post #78)
Now, we already know that Van = 120 @ 0 and Vbn = 120 @ -120. How would one use KVL and phasors to determine the magnitude and phase of Vab?
Rick Christopherson said:I hate to say this
but your understanding of the principles you are arguing is so light that you don't even realize that you have just grossly contradicted your founding premise.
mivey said:If it is a terminology difference, just use the other person's terminology (even if you don't like it) and see if you have the same understanding of the concept.
You are correct, and I apologize. It has been very difficult to read the contumelious tone of Rattus' postings (even crossing threads to throw barbs) and not let it get to me at times. What I said, I did not say in anger. I had walked away from the computer for 2 hours before making that posting. What I said was an observation, not an intentional insult.iwire said:So why did you?
Rick Christopherson said:Nevertheless, as inappropriate as that opening was, it does not change the magnitude of the statement made (Re: CW Vs CCW), and I would like to hear a response.
jim dungar said:All this talk about KVL, lets not forget that current also needs to be evaluated.
Given: a system defined as two voltages connected in series with a single 2 wire resistor connected to the resultant V12. Isn't there a single load current and two source currents? And shouldn't the source currents be in the same direction as their voltage?
The way I see this discussion:
In Rattus' system, with sources V1n and V2n the source current from one of them has to be opposite its voltage.
In Rick's system, with sources V1n and Vn2 the source currents are in the same direction as their voltages.
I know that both systems can be solved (after all if, A' = -A then -A' = A). But, one of them is more intuitive to me as an engineer that the other.
Cause I like to have math models be consistent as they move from the simple to the complex.mivey said:How about one diagram for the three-phase phasors and one diagram for the single-phase phasors? ...
I find this dismissive and insulting. If this forum is going to hold me to a standard of decorum, then it should be holding you to the same standard, and so far that does not appear to be equivalent.rattus said:Should be nuf sed.
No, I will not respond until we are through with this topic. I have only been here a few weeks, but I have already learned that one of your primary tactics in a discussion is to distract others away from a difficult problem by redirecting them to another issue. We'll come back to it after you have addressed the current issue.rattus said:Now respond to my post #78 which contains head to head phasors. How do we treat them?
rattus said:Just trying to demonstrate that V1n and V2n exhibit a phase difference of 180 degrees, and I have done that. The current will take care of itself.
[B said:mivey][/B]
If one extends the poor model, it gets real funny looking. And as jim pointed out in posts, 86 and 94, the currents don't follow the sources real well.coulter said:Cause I like to have math models be consistent as they move from the simple to the complex. ...
jim dungar said:Why do you dismiss this little issue? In a purely resistive circuit your system has one source whose voltage is "180? out of phase" with its current. So are these equations the correct ones for your system, V1n=IR and V2n=-IR?
rattus said:Jim, let the current be I12 which is in phase with V1n. Then the sense of the current is leaving V1n and returning to V2n. You would expect the return current to be out of phase with V2n--not unlike return current in a DC circuit.
Rick Christopherson said:I hate to say this because the discussion has been going moderately well, but your understanding of the principles you are arguing is so light that you don't even realize that you have just grossly contradicted your founding premise.
You just asserted that the "Summation is clearly stated as CCW", yet you defined your voltage between points C and G in a clockwise fashion.
This is the single most critical point I have been making from the very outset. You have defined all of the voltages in your phasor diagram in a counterclockwise direction, with the exception of the voltage between points C and G. You defined this voltage in the clockwise direction.
Here is a hint: Take a look at the nodal analysis diagram that you have already agreed was correct.
I will address the rest of your posting at a later time, but I do not want to distract you from this single, rather critical, point.
Rick Christopherson said:So without realizing it, you changed from counterclockwise to clockwise in your summation when you got to nodes C and G. This is the reason why you needed to subtract.
Diagram Notes: The voltage from point X to point Y is defined as the voltage of Point Y minus the voltage of point X.
Also Note that I prefer my voltage naming convention to be Vab = voltage from a to b. I mention this only because I have noticed my convention is opposite from Rattus', but it does not play a role in this discussion so long as we know this and do not intermix the two.
jim dungar said:If the current is I12 and it is in phase with one source V1n then it must also be in phase with the other source.
I expect resistive current to be in phase with its source voltage. Yours can not be, especially if the source is a center tapped transformer referenced as you have.
