- Massachusetts
480sparky said:Wrapping with tape, however, is a common spec for large commercial jobs.
So how much tape?
One wrap, two, ten?
iwire said:So how much tape?
One wrap, two, ten?
iwire said:The company I used to work for wanted us to tape all devices, I almost never would and would not ask those under me to.
chris kennedy said:I don't tape. Heres a tip for any youngsters out there.
If you tape a device and when pulling wire, break the last inch and twist it well between your fingers. This gives you (more importantly ME) a nice flag to grab to undo the tape.
jerm said:* steel fittings only, with interior bushings. (they cost about 4 times the usual stuff)
* nothing smaller than 3/4 EMT
* compression fittings only (indoors! cmmon!)
jerm said:We do primarily "large commercial jobs", some medium in there, no homes.
I've never seen a spec for tape. But I have seen the following, which I believe the architects do to increase the cost of the job and thus their percentage.
Jeremy
Tulsa, Ok
iwire said:I believe the thought is compression fittings provide a better ground fault path.
peter d said:Steel is actually cheaper than die-cast fittings, and the insulated throat is nice for hardly any additional cost.
peter d said:Maybe they do. But I can't imagine the difference is all that great.
iwire said:Also any job spec that has a 'compression fitting only' requirement will likely have a copper EGC requirement.
spectra05 said:in class our teacher has us cover the terminals of all switches and receptacles with electrical tape anytime their in a metallic box (like for drywall). i was wondering where in the NEC it says that you gotta insulate the exposed terminals of devices like switches and receptacles. lookin for the specific code section plz and explination if possible
e57 said:Same here - Installed correctly the receptical does not have enough play to hit the sides.
Lawn guy - why would the receptical be in prior to mud and paint without a cover plate?
LawnGuyLandSparky said:Many times devices are installed prior to the 1st coat of mud. Often they're live because the temps have been rendered worthless due to the "closing in."
