Hello to all- I have a house in Virginia that has an old fuse style main panel located in a closet. I want to replace the fused panel with a breaker panel with main breaker. The current panel has closet is 31 inches wide and has a height of 91 inches. The new breaker panel door will be able to be opened 180degrees. None of the lighting and receptacles circuits are grounded. My questions:
1. Can I install the new breaker panel back in the closet?
2. Do I have to do anything about ground circuits?
3. What else might I have to do to pass inspection?
4. What code cycle is VA in?
Thanks to all who answer!
