mivey
It is probably the most common reference in the world.Actually, it is not a logical choice, because this is a 120/240 volt system, and your 240 volt loads do not share this common reference point.
A phase shift does not have to include an actual time shift. A phase shift and a time shift can also be related through the reference frames.But I don't think that there is any doubt in anyone's mind that what is physically happening in our all too familiar center tapped transformer is an inversion, not a time based phase shift (i.e., delay).
No one scurried away from a noise analogy. In fact, I provided two examples using noise analogies. The scurrying was done by those who chose to ignore the fact that a phase shift does not have to be produced by a time shift. Dozens of references were provided illustrating this fact and to ignore the fact is denialism.It's the same reason why they scurried into the shadows over the noise analogy. It reveals that the phase shift is apparent and mathematical, and not physical. Two cross sections cut in each of the windings will show that the electrons are flowing in the same direction, regardless of their chosen points of reference.
Neither does the use make it incorrect. It is an industry-recognized use. I provided pages of references illustrating that fact.As I pointed out, many in audio commonly use "180 degrees out of phase" to describe a signal inversion, as well. Although we all know what they mean by it, that doesn't make it correct.
Exactly. And we commonly use transformers to produce phase shifts that are not the result of time shifts. These phase shifts are the results of physical shifts created by taking voltages from different terminals and in different directions in the windings.You may continue treating it however you wish but it does not change the way a transformer works.
240 volt sources: 3 phases max at any given timeWell, depending how one treats the split phase transformer, one can count 5 phasors with 5 phase angles. Technically that is 5 phases. Even if one of the transformers is omitted, its L-L voltage is still present. We still call it a three phase service though.So how many phases are there in a 120/208/240 high leg open delta?
Your reply was to my specific example of a single voltage across two terminals.With a center-tap transformer we have more than two terminals thus more than two voltages.
The 'name' of a voltage, Vxy, does not contain any directionality except in the sense of "from node X - to node Y". When paired with an angle, it becomes simply an identifier which is then used to as a means to differentiate one voltage from another voltage with the same angle.You are not using correct notation. By sticking an angle on the end of the name, you are mixing the name and value. It is like saying the "direction from x to y in the north direction is in the north direction".
I was talking about the conjugate of an angle, so I am not sure what point you are trying to raise.Also, while a pair of conjugate angles adds to 360?, mathematical conjugation is something completely different.
Actually, every one of you did scurry away, giving one reason or another that it wasn't applicable.No one scurried away from a noise analogy. In fact, I provided two examples using noise analogies. The scurrying was done by those who chose to ignore the fact that a phase shift does not have to be produced by a time shift. Dozens of references were provided illustrating this fact and to ignore the fact is denialism.
Really? Is it time to resort to petty accusations? How about we try to keep the discussion on point instead of going down the path of taking jabs at each other?Mivey,
It looks like you are getting argumentative by misrepresenting the context of my posts rather than addressing any actual inaccuracies.
And your reply was in reply to my discussion about the original topic: the voltages across three terminals.Your reply was to my specific example of a single voltage across two terminals.
You are still mixing the name with the value as I noted.The 'name' of a voltage, Vxy, does not contain any directionality except in the sense of "from node X - to node Y". When paired with an angle, it becomes simply an identifier which is then used to as a means to differentiate one voltage from another voltage with the same angle.
It appeared you were referring to the "conjugate" of the phasor. Perhaps I misunderstood your point, but the conjugation of a complex value is not taking the negative of the angle of the complex value; rather it is taking the negative of the second term (or the imaginary term for complex numbers).I was talking about the conjugate of an angle, so I am not sure what point you are trying to raise.
I'm not going to go digging back for your post, but I am pretty sure you did not provide any references that a phase shift can occur without a time shift, as you claim. If you did provide some sort of reference, then I can assure you that it was discussing a mathematical phase shift, not a real phase shift. And since that is the topic at-hand, any such reference would be circular and useless.
That's because they are only mathematical. You are using circular logic for an argument. Find a single reference that says you can have a phase shift that is not a time shift, that is not referring to the mathematical transformation of an inversion into a phase shift. You can't and you never have!The phase shifts we are discussing with transformers does not require a time shift.
You have already crossed that line. You accuse me of not being able to apply subscripts correctly. You infer that I do not understand phasors and their conjugates.Really? Is it time to resort to petty accusations? How about we try to keep the discussion on point instead of going down the path of taking jabs at each other?
I did not say you were not able. I said what you posted was incorrect notation.You accuse me of not being able to apply subscripts correctly.
You were the one who mentioned phasors and their conjugates and gave an example of with a negative applied to the angle. You were making some point about how conjugation and inversion were different. Well of course they are different but who was conjugating the complex number? Your point was not clear and I said so.You infer that I do not understand phasors and their conjugates.
I see it differently. I questioned your post that I believed to be in error. I stated why I thought your methodology was incorrect.You have already crossed that line.
Get over yourself.I have no respect for your 'discussion' practices.
I can and have provided dozens of references. Here is just one:That's because they are only mathematical. You are using circular logic for an argument. Find a single reference that says you can have a phase shift that is not a time shift, that is not referring to the mathematical transformation of an inversion into a phase shift. You can't and you never have!
2. Angular Displacement (Phase Shift)
For standard three-phase connections the phase-to-neutral voltage on the primary side either leads that on the secondary by 30? or is in phase with the phase-to-neutral voltage on the secondary side.
The delta wye and wye delta connections produce the 30? phase shift.
What does that reference have to do with your assertion that a non-mathematical phase shift is not a time shift?I can and have provided dozens of references. Here is just one:
Westinghouse Distribution Transformer Guide:
What does your assertion that a phase shift must be the result of a time shift have to do with anything? Clearly, our industry also recognizes phase shifts that are not the result of time shifts. Whether or not you agree with that is your own personal preference.What does that reference have to do with your assertion that a non-mathematical phase shift is not a time shift?
Well there's a shocker.:roll: But considering your historic technique, I'll just consider the source.I'm in full agreement with Jim regarding your discussion techniques.
A minute ago you claimed you could, and have, produced dozens of citations. You haven't produced a single one. And now you want to scurry away by diverting the topic.What does your assertion that a phase shift must be the result of a time shift have to do with anything? Clearly, our industry also recognizes phase shifts that are not the result of time shifts. Whether or not you agree with that is your own personal preference.
You specifically asked for:A minute ago you claimed you could, and have, produced dozens of citations. You haven't produced a single one. And now you want to scurry away by diverting the topic.
Produce a single reference that backs your assertion that a non-mathematical phase shift does not require a time shift.
No you didn't. Where in your reference does it support your assertion?...and I produced a reference that says you can have a phase shift that is not a time shift that was not referring to the mathematical transformation of an inversion.
