Wiring a New House
stickboy1375
Litchfield, CT
I doubt it's a violation, but the plywood is just easier to install, remember your going to have catv and phone run back to somewhere... it just makes the install easier... Would you rather just shoot a piece of plywood to the wall and screw your panel to that or drill a bunch a holes and rawls for a panel?
Cavie
SW Florida
I have not seen a 2 gang plastic box rated for 8/3 rx yet. not to say there is not one, I just have not found on on a job yet. I turn them down.
stickboy1375
Litchfield, CT
http://www.alliedmoulded.com/outlet_range.cfm
Sorry Cavie...:)
peter d
New England
stickboy1375 said:
Not to tell you what to do, but shoot a piece of 3/4 plywood to the foundation first...
I would install the plywood too.
That said, I don't understand why this suddenly becomes an issue in residential settings. We frequently mount panelboards, disconnects, and other equipment directly to concrete in commercial and industrial work.
stickboy1375
Litchfield, CT
Sonny Boy said:
So use @12 X 1/2" Long screws to secure the panel to the plywood instead of, say, #12 x 1-1/4" Long concrete fasteners?
Has to do with ease of installing other equipment, not just the panel... for instance most homes I do will have a 40 circuit panel, a 24 circuit panel, phone & catv splices, gfi receptacle, and maybe a alarm panel... so plywood makes the install easier.... but only IMO...
Sonny Boy
Washington
Clarity
Clarity
The panel will be recessed in the furred basement wall.
George Stolz
Windsor, CO NEC: 2017
Service Manager
Sonny Boy said:
Need some pointers.
Mike, I've skimmed over your post record, and I am under the impression that you are not a licensed electrician. Do-It-Yourself advice is prohibited by the forum rules, and I am not convinced that you are a legitimate electrical contractor.
There are some basic principles that should be known from serving a conventional apprenticeship, and with the incomplete picture I see, it seems to me you haven't served one.
I am closing this thread, and sending you a PM for more information.
George Stolz
Service Manager
I am re-opening this thread, and issuing the customary apology for the delay.
Be it known that Sonny Boy is in fact a licensed electrical contractor in the state of Washington, and by the evidence cheerfully presented does have over 20 years in the industry.
Mike, I would advise you to edit your profile, under occupation, to "Electrical Contractor". This will slow down folks reporting your posts as DIY when they are not.
So, sorry for the delay, and proceed. :)
LarryFine
Henrico County, VA
Sonny Boy said:
Are there any problems with using romex staples in I-joists?
Not the way I do it. Trying to staple to the web of the joist is crazy, because of the bounce. I staple to the top face of the bottom 2x3 or the bottom face of the top 2x3.
bikeindy
Indianapolis IN
j_erickson said:
Using 1 mini offsets the savings of a 30/40 vs. 40/40 for me. I pay $10 more for a 40/40 BR series panel. A mini cost me about $10 more than 2 singles.
This is what I can't figure out I see these 30/40 panels all the time and they are loaded with tandems and have space left in the rest of the panel. This makes no sence to me with the cost of a tandem being so high.
bikeindy
Indianapolis IN
It makes for a nice place to secure your romex to as it exits the panel. In commercial you will have conduit that is secured to the concrete with mini's i suspect if your not using unistrut.
LarryFine
Henrico County, VA
It took me about a minute to figure out what you meant by "mini's."
I was thinking "mini whats?" Ah! Mineralacs! :roll: Duh!
I prefer stapling to 2x4 than plywood. Even on plywood, I'd add a 1x4 or 2x4.
growler
Atlanta,GA
Sonny Boy said:
Passed two inspections already with the panel mounted to the concrete.
Never use passing inspections as an indicator of quality work. Many times it just means the inspector doesn't know what he's doing.
My understanding of why you shouldn't mount a panel to a conctete wall in a basement is because of moisture. You are not allowed to mount non-pressure treated wood directly to the wall or floor for this reason.
It's not really a problem of mounting to concrete such as in an industrial area. In a basement the concrete wall is just a barrier between the panel and moist soil. Concrete is porous and will allow small amounts of moisture to seep through.
It has become common practice to mount the panel on pressure treated plywood so the panel won't rust out ( provides a barrier ). And it gives you something to staple the Romex to.
growler
Atlanta,GA
Stickboy1375, you are right it's not one of those clear cut violations that's enforced everywhere.
I believe that an inspector can say that a concrete wall in a basement is a damp location unless you provide a barrier to the moisture.
Here they will fail you on inspection for not having the plywood. If it were a big deal I guess people could argue the point but it's just easier to mount the pressure treated plywood.
Even if it were not required it would still be a good practice.
dnem
Ohio
Laying half a sheet of plywood on the wall works especially well when you shoot it to the wall with a powder actuated shooter. . Hold it up, bang, bang, bang, then use regular wood screws and a cordless drill on your panel and your panel plug box. . Get it close to level for the first screw and pivot off the first screw to get it exactly level for the remaining screws. . Anything else you want to add just screws right on. . It doesn't get any easier than that.
David
SmithBuilt
Foothills of NC
The International Building Code requires all wood in contact with masonry to be treated.
May not be a problem with the electrical inspector but the building inspector could say something.
