In residential construction the panel cans are prepunched with 1/2" ko's everywhere. When it is reqiuired to punch a large hole that does not line up with a factory hole you end up with unintended ko's getting partially punched out leaving holes in the can that cannot be filled with ko seals. what i have found to be the cleanest way to deal with this is I screw on a 4sq cover with 4 -8/32 tapped into the can at the location i need to punch my hole . Then i punch through the can and the cover leaving a very clean solid can and installation. I could use very large reducing washers but it never in my opinion creates as solid installation.
Is a 4sq cover required to be listed for this installation, and is this a code compliant installation
thanks for your time
geoff
geoff
