peter d
- New England
Blue boxes are sold at supply houses too. :roll:
No, Jim's absolutely correct. If you use Carlon boxes purchased at a big box retailer you are a hack and always will be.
No, Jim's absolutely correct. If you use Carlon boxes purchased at a big box retailer you are a hack and always will be.![]()
I would never consider installing wire nuts without first twisting.
Then I say the family should be forcibly removed from the property and placed into state custody, the house razed and hauled to a site capable of handling hazardous waste (remember, it contained boxes from Home Depot!), and the hole in the ground filled in. That'll teach them to use Carlon boxes next time.
Oh, I totally agree. Then they should never be allowed to build another house on that site because it is permanently contaminated.
Alot of wire wire nut manufacters due not require pre-twisting I always do. I have seen a brand of wire nuts (can not remeber the brand) were it said do not twist wire. So it would be Nec a violation to twist the wires
Sung to the tune of "I'm a Girl Watcher." :grin:I'm a pre-twister.
Or until the tip of the wirenut pops off.I'm not sure it matters if you pre-twist, but if you don't, then it's probably a good idea to crank that wire nut down until it stops.
That just proves it's operator failure.One other interesting note. This was a kitchen remodeled completed in the last 2 months. It did not take a lifetime of arcing to melt that wirenut.
Upon closer examination, those boxes are light blue which means they are the EZ Boxes from Cantex. They are not sold at big box stores. Jim was wrong again.
That may be the result, but they are listed as pressure wire connectors, and, with rare exception, do not require pre-twisting. It's still encumbant upon the installer to make a proper connection, whether pre-twisting or not.When I pretwist, that's what makes the electrical and mechanical connection. The wire nut is just for insulation.
It looks like they didn't:Note that they did call that EC back for warranty.
I wonder why they didn't. :-?I went on a service call yesterday. One of the kitchen counter receptacles wasn't working.
I resemble that remark!I see blue boxes were used, were they the cheap ones bought at big orange ? When i see them it's a red flag that installer was cheap on material and likely labor too.
They're a lighter blue than the Carlon Zip-Boxes.
Seriously, I use them. Why not? :-?
Using a more expensive product doesn't automatically correlate to superior work, either. It just means more money went into materials, perhaps even causing corner-cutting on more important matters, such as skilled workmanship.If installer used low price boxes its just likely wasnt only place he cut corners.
As should be obvious by now, I must challenge that statement. I haven't heard a real reason blue = hack yet.Still proof of a hack.
