mivey
That is not what I said. I said to get "the current from the rest of the circuit" to flow through the conductor you would need to add voltage. I also gave a supporting statement for clarification. You have, and should, agree with my clarification. Why ignore the clarification and completely redefine what I said? Stop extracting part of my post and adding your own clarification to that extracted piece and you will hear what I am saying.Your first statement said that if you increase the impedance in a circuit (or replace a superconductor with a real conductor) that you will need to increase the voltage to get current to flow through the circuit.
I have heard what you are saying and you agree that for the same current to flow to the same load, but across an added resistance, you will need to step up the voltage. You have already agreed with my point. No need to keep doing so.
