gar
- Ann Arbor, Michigan
- EE
090805-2029 EST
erickench:
This is in response to your post #18.
I do not know what a lightning arrestor is. Ideally it would be something that would prevent lightning currents from entering a building.
I think some of the goals would be:
Low pass filters on all wiring into or other conductors into a building.
No supplemental paths to earth within a building.
Low pass filters imply shunt capacitance from all conductors into the building.
An incoming water pipe is already in contact with the soil. Connecting it to the ground electrode system outside of the building would be desirable.
All connections to and including the ground electrodes should be wide thin sheets of copper to provide low inductance and RF resistance.
On conductors at the entry point to the building should be shunt transient voltage limiters including gas discharge, and semiconductor transient limiting devices.
From some old references on my web site;
http://www.harvardrepeater.org/news/lightning.html
grounding paths
http://www.electrical-contractor.net/ESF/Lightning_News/Standard_780_Removal.htm
erickench:
grounding paths
