jrannis
- Fort Lauderdale/ Miami
Normally I would have said this is on your dime, but I believe that the mirror was installed incorrectly, especially with the cutouts for known electrical devices.
If it was installed by the general contractor then you might have a harder time arguing fault. However, if is was installed by the glass supplier, then there is a reasonable expectation that they should have done it properly and will accept fault.
I am assuming a 54" x 80" mirror was 1/4" glass, so tightening a #6 or #8 screw would not have enough force to fracture this thick of glass on its own. The mirror was pre-stressed and was prone to breaking long before your installer touched it. There is no guarantee that you won't get the full blame for this, but a reputable glass installer would step up and take responsibility. This is definitely something you should be contesting, and I suggest you point out the strength of 1/4" glass as part of your process.
I agree, its a stress fracture. The mirror was not properly installed.
It would have cracked anyway
