- Simi Valley, CA
OK so here it goes... I've got a 1 stall garage. Standing in the driveway looking into the garage with the big garage door open I put a panel on the side wall in the garage 6ft back from the front (front being the garage door opening side). Now if you walk in and stand facing the panel and look up, the garage door rail is above my head 7' off the floor and 2' out from the front of my panel. My city ordenence extended the 6'6" or to top of service gear code to 8'6" on new constuction. So that garage rail is realistically in the working space...(garage door open or not)...I just wanted to know if any of you had heard of this....It pretty much eliminates putting a panel in a garage on a side wall unless you go back farther than the garage door rail extends.. I'm pretty much just venting my frustration on some of the silly things inspectors come up with..Really?? a garage door rail? Really??
OK speaking as an inspector, I'd say good call.
Now speaking as an inspector again, I may go in and argue that they have no justification for changing the code from 6'6" to 8'6". Here in CA to change a code section the reasons must be topographical, geographical or climatic conditions. I have a feeling that their justification would not fall under any of those peramiters.
You always hear "pick your battles", this call is being made at final, I would say this is one worth fighting. You may not win, but you have nothing to lose either.
