back in the early 80's Athens Georgia had, in their local admendments, one that prohibited soldered joints--probably was a reason for that rule but I've always wondered why.do you still solder your joints? if so why? if not why?
Boy, when you quit using black pipe I bet that saved you even more.![]()
"What's that green wire doing in this new-fangled BX?"Boy, when you quit using black pipe I bet that saved you even more.![]()
"What's that noise!?"Yeh, but not quite as much as when we switched to electric drill motors.
Don't laugh. I've seen fixtures on K&T rewires that were hanging from sealing-type pipe hickeys where the gas was still on.And a few years later they decided they probably should shut the gas off.:grin::grin::grin: Little joke there.
cans, how long roughly on average would it take for one person to wire up a home like this? Just need a guess.In my younger days, 1000 sf per 8 hours was a good estimate. That was pulling rope into set boxes bonded up.
Also had an inspector for the rough inspection say he wanted all the wires in the boxes to be stripped, spliced and ready for devices, does this sound common to anyone?
He is like most other AHJ's and EC's. If you send a different man on the job, it takes twice as long to figure out the make-up is... because the cabling reference point has been covered up. Make-up and pigtailing is one of the main reasons a good inspector wants to see a completed bonding system before closing-in.
The T&T rocker would sh*t bricks if the strip-out is not done because sheathed NM is near impossible to stuff in a 1 gang. Your boxes will get filled with mud in revenge. rbj
I've been doing Commercial,Industrial, and Heavy Industrial all my life.
For the guys that can do a house in a day I wonder how much time is spent
on "Punch" "hot-check" and other words to describe turning on the power
and metering all the circuits and devices to make sure everything works.
Other than ceilings, the black pipe I've seen was original for the wiring, and used for exposed sections of K&T whole-house wiring, probably just before the use of BX.
quote]
Me too and it was "shocking" to say the least when I learned that green used to be used as a hot.:grin: It seemed much funnier when my brother found out.![]()
5 days on the rough, 1 day on the service, 3 days on the trim... That is if everything goes smooth with no problems or issues.
It is hard to find a "well rounded" electrician.
How else would an inspector check the correct length of ALL conductors? Yes they could be cut shorter later. Again the connection of conductors. The EGC's. The separation of grounded conductors of different circuits. Etc.
