Whats the reason i am shopping around and it is a $150.00 differance between the 2.
All the panels at my apt are Homeline and doing just fine.
Burnt bus stabs are usually due to improper installation of the breakers or use of old breakers where the little dab of lube in the stab clip is dried up or missing.
I wanna clarify when I said I've seen alot of burnt busses, I didn't mean Homeline,I install those often. I meant older panels, as you said.
But there are plenty of old QO's ,,,and I've never seen their buss fail
So do other brands; the handles.Also, the QO have trip indicators.
Would you put QO or Homeline in your home?
Yes I would.
When I am in USA side { wisconsin } I useally go either way I have no issue with both HOMELINE et QO seri?s.
I only have two HOMELINE failure all it was due the wrong location for the load centre to be mounted due the consendation really screw up the alum bussbar otherwise no issue AFAIK.
Oh yeah Both HOM et QO do share the same guts but the housing is diffrent that all.
Merci,Marc
{ I do get a QO show up in France once a while }
Are you talking about the internals of the breaker?
If so, have you taken one of each apart and compared?
McClary.,
I did took both QO120 and HOM120 apart and the interal parts are the same only two noticeable diffrence is that the QO do have trip indenticator while the HOM do not have it.
And the handle shape is little diffrent but everything else inside of it is the same for both series.
I think 480Sparky did the same thing as well but I will let him speak his word in here.
Merci,Marc
McClary.,
Merci,Marc
Wasn't me. I think is was Marc Shunk.
