A/A Fuel GTX
- WI & AZ
- Electrician
Yes I would.
Pithy:grin:
Yes I would.
Go for broke, I-Line and QOB.![]()
I'd use either.
: Originally Posted by mcclary's electrical
Also, the QO have trip indicators.
So do other brands; the handles.![]()
Not only would I not use one in my home, I would not use one in your home either.Would you put QO or Homeline in your home?
I have a Homeline in my own home. Does that answer it?![]()
Depends on if YOU put it there![]()
How do you sleep at night knowing that if a breaker trips you won't have a little orange thingy to tell you which breaker to reset.
Never admit that in public:grin:When I am in USA side { wisconsin } I useally go either way.........
I have installed hundreds of homeline. For residential they are great . Now if commercial i would want QO because chances of full loads are greater.
I have replaced a lot of mains on qo panels due to water instursion. Their branch breakers are excellent, but the mains need to be sealed around the lugs to prevent water from pooling inside the main. I have emailed square d about this issue, they more or less said not there problem, stop the water intrusion. Next time you have to replace a main drill the rivets out and you will know what I mean. Yes I know water in panels is bad, and that is the main problem, I have yet to replace a siemens main because of water intrusion. Yes I do have qo in my house!
